Skip to product information
1 of 1
Aim DTA S60 Interface Lead MXL Evo
SKU: ECU-DTA
€97,95 EUR
€97,95 EUR
Aim DTA S60 Interface Lead MXL EVO.
Aim Looms, Cables, Connectors and Harnesses are highly engineered to withstand the intense rigours of the Motorsport environment.
Aim developed special applications for many of the most popular ECUs. By special applications, we mean user-friendly systems which allow you to easily connect your ECU to our high tech data logger. You only need to install a harness between the logger and the ECU.
Once connected, the logger displays (and/or records depending on the logger on the ECU data stream and configuration) values like RPM, engine load, throttle position (TPS), air and water temperatures, battery voltage, speed, gear, lambda value (air/fuel ratio) analogue channels
