Aim Tech
"I now have various Aim products, Strada, GPS, Various sensors etc all great, very quick delivery with no hard sale when you need advise."
Aim Fuel Pressure Sensor 1/8 NPT 0-15 PSI
The Aim Pressure Sensor is suitable for brake, oil, fuel and water pressure readings, reading pressures up to 15 PSI. This pressure sensor measures exactly how much pressure passes through.
The Aim 0-15 PSI Pressure Sensor is available in 1/8 NPT and is fitted with a 4-pin 719 male binder connector to suit Aim loggers, dash loggers, lap timers and dash displays. Many aspects affect various engine pressures, so knowing your engine has the correct amount of pressure is paramount to longevity and performance.
If there is a pressure change, incorporating a pressure sensor into your setup will allow it to be detected and signalled to prevent the worst. You can see through live telemetry about what’s happening as the sensor turns the physical force of fluid pressure into a predictable electrical signal that can be monitored to protect your engine.
The Aim Pressure Sensor is installed directly into the fluid or air line of the system being monitored. Inside the sensor is a sensitive internal component, typically a thin diaphragm.
As the system generates pressure, whether from a pump, a mechanical piston, or compressed air, that pressure forces the diaphragm to flex or bend. The sensor precisely measures the degree of this movement and converts that physical displacement into an electrical voltage signal:
This is a linear scale. This means if the pressure is exactly halfway (7.5 PSI), the voltage will also be exactly halfway between 0.5V and 4.5V (which is 2.5V). This electrical signal is what the vehicle’s data logger or ECU (Engine Control Unit) translates back into a pressure reading for you to see.
The pressure sensor allows you to detect fluid and air pressures. It offers a high level of reliability and endurance and is protected against the high vibration, shock and high temperatures found in motorsport.
We also offer unterminated sensor that are designed to work seamlessly with Bosch, MoTeC, Cosworth, or other manufacturer hardware, making it easy for you to integrate the reliable and efficient Aim Pressure Sensors into any setup.
You can expand your system with a range of products from the ACC3 Analogue CAN Converter, Displays and Loggers, Data Hubs and more.
1/8 NPT 0-15 PSI Pressure Sensor
Overall rating: 4.25 / 5 from 4 reviews.
Review topics: [].
"Product is good. I needed set up advice for it to make it work with other AiM products. I contacted support but got no response. I notice I have the ability to “purchase” tech support time. But I’m not prepared to pay the support. It should be freely available for a customer having bought an item through the shop."
"非常稳定的元件"
"Kits good but massively over priced"
