A Compact Motorcycle GPS Dash
Display your data and improve your riding and track day experience with advanced motorcycle data logging and data acquisition capabilities.
The MXM Bike Dash Display & Data Logger on a motorcycle cockpit installation
Why Choose the Aim MXM Data Logging Dash
The compact MXM dash display features advanced data logging capabilities and is designed for riders who need all the essential information to monitor the behaviour of their motorcycle and improve their performance. This dash is designed to acquire and display data from your ECU, as well as from the internal GPS receiver, analogue/digital inputs and predefined math channels.
A Wide Range of Data Sources
The MXM data logging dash features 2 CAN connections for obtaining information directly from the motorcycle's ECU, with a wide range of compatible ECU systems available to choose from. The MXM offers the most straightforward method of installation whilst offering 4 analogue and 2 digital inputs for additional data input.
Load video: MXM motorcycle dash video render with two power outputs
Two Power Outputs
The MXM motorcycle dash features two power outputs that can drain up to 15A each. These outputs can be configured to turn on or off depending on the value of the analogue or digital inputs. This functionality allows you to automatically control external systems, such as switching additional lights on or off or activating and deactivating controls when specific events happen.
Load video: Delta times LED display feedback on the MXM LCD data logger
Sharp Liquid Crystal Display
Making use of a sharp liquid crystal display (LCD), you can select which information you want displayed, and the backlight can be switched between a range of available colours, all with high contrast and easy-to-read graphics.
Load video: Integrated shift light array interface and customisable alarms for the MXM
The MXM display has an integrated shift light system that features 5 fully configurable LEDs, which can be customised to your requirements and for each gear. Two further LEDs can be configured to operate as warning alarms, allowing you to customise colours, alarm types (solid or flashing), flashing frequency and accompanying text messages. Alarm priorities can be set to suit your specific requirements.
Data Recall On-Screen
The information that is displayed on the screen can be fully configured to prioritise the most important information for the rider. If there’s too much information on the screen, the rider can scroll between multiple pages using the integrated buttons so that nothing is missed.
After the session has ended, all the data can be recalled on the screen, including a summary of the rider’s best laps along with max/min RPM, speed and temperatures. If you prefer going through the data in more detail, the MXM features a Wi-Fi function to enable fast and secure data transfer to a laptop or PC up to 50 metres away, so you no longer need to take the laptop to the motorcycle.
MXM Expansions list; SmartyCam 3, ACC3, Data Hub, GPS, and more.
Expand your MXM’s capabilities with a range of compatible accessories to guarantee precision and reliability.
  • Display: 5" Display
  • Alarm LEDs: 2 RGB freely configurable
  • Shift Lights: 5 freely configurable RGB LEDs
  • CAN Connections: 2
  • ECU Compatibility: +1,000 industry leading ECUs
  • GPS: Integrated
  • Digital Inputs: 2 speed inputs, coil RPM input
  • Wi-Fi Connection: Yes
  • Internal Memory: 4GB
  • Connectors: 37-pin Motorsport connector for Legends cars + 4-pin power connector
  • Weight: 330g
SKU: MXM
Part Number: X87MXM0000
MXM User Guide
MXM Tech Sheet
