Aim PDM32 & PDM Dash Display with Race Icons
Choose Accessories
Aim PDM32 Data Logging Kit
The Aim PDM32 system combines advanced power management, real time data display, and precision GPS tracking into a single integrated solution. Its 32-channel power distribution module replaces traditional fuse boxes and relays, while the fully configurable TFT display presents critical information through customisable layouts and intuitive race icons. When paired with the onboard GPS Module, the system also delivers accurate lap timing and track-mapping capabilities for a complete, race-ready electronics package.
Why Choose the PDM32 Race Dash Display Kit
The Aim PDM32 is a 32-channel advanced power distribution module designed to power a multitude of vehicle circuits, removing the need for traditional fuse boxes and relays. It allows for a simplified wiring harness with increased reliability and control functions. Paired with a TFT Display with Race Icons, a fully configurable display with a range of layouts to choose from, and a GPS Module that provides easy lap timing and lap position for track mapping, this kit is the ultimate set-up for full vehicle control and performance improvement.
PDM32 Power Distribution Module
The PDM32 features 28 high-side outputs and 4 half-bridge outputs: 4x rated up to 20A (high power), 12x rated up to 15A (mid-power), 12x rated up to 10A (low power), and 4x rated up to 35A (half-bridge), with a total continuous max current of 120A. Each output provides feedback to the data logger to provide vital information such as open circuits, short circuits, high/low voltage, and the number of fault retires. The time between the retires is user-definable. All outputs can be configured as PWMs for a soft start/stop. All of the PDM circuits can be set up and monitored via the Race Studio 3 software.
The PDM also features 8 analogue/digital inputs, 4x digital-only inputs and 2x speed inputs, and can receive and record data from the following sources:
- ECU: Over 1,000 protocols available
- Digital/analogue inputs
- Internal nine-axis EMU
- GPS: For lap time and position
PDM Dash Displays with Race Icons
All versions have fully user-configurable displays and offer a range of layouts, and are available with "Road" or "Race" icons. Race icons with this particular kit allow you to apply conditions to the LED icons.
Pre-Configured Pages
The Aim PDM Display can show the RPM scale and all the data you need, like speed, water temperature and oil pressure, lap times and much more. You can customise pages to suit your requirements, including up to four additional fields. Define what data is shown with the end of scale and measure units. Swapping between the pages is easy; just use the push buttons.
Integrate a Reverse Camera
By connecting an Aim PDM32 to your Aim PDM Display - giving it the power to log your data - you can download your data and with Race Studio 3; create, modify, delete, import and export configurations of:
- All channels
- ECU drivers
- Math channels
- Display pages
- Digital outputs
- Alarms
- Shift lights
- Expansions
GPS Options
The GPS09 Module provides easy lap timing and lap position for track mapping. The PDM has over 4,000 racetracks in the database, so once you arrive at the track, the system already knows the timing points so that you can arrive and drive.
Note: The GPS09 Module is available with cable lengths of 0.5m, 1.3m, 2m or 4m to suit different applications. We also have an option for a roof-mounted version which is available with 2m or 4m length cables. Both versions come with a 5-pin 712 male binder connector.
Aim CAN Expansion Keypads
Optional Wiring Solutions
Pinouts
PDM32
Chosen Display
Grey & Black 35-Pin Plug & 70 Gold Pins
SurLok Power Connector
PDM32 LVDS Connector Cable
Download Cable
CAN Expansion Cable
What does a PDM do?
At Aim, we have 2 PDM modules to suit different vehicle setups: PDM32, which has 32 output channels for more complex setups and PDM08, which has 8 output channels for simpler or compact setups. The 'best' PDM depends on how many outputs you need and the size of the setup.
- Output Channel: The PDM32 manages 32 circuits, while the PDM08 manages 8.
- Output Types: The PDM32 features 28 high-side outputs and 4 half-bridge outputs, whereas the PDM08 features 8 high-side outputs.
- Capacity: The PDM32 is designed for complex race cars, while the PDM08 is suited for smaller, simpler setups.
- Hardware Configuration: The PDM32 utilises two 35-pin AMP connectors, compared to one 35-pin AMP connector on the PDM08.
- Camera Input: The PDM32 includes two analogue camera inputs to add a rearview mirror camera display.
The PDM32 has 8 analogue or digital inputs, 4 digital and 2 speed. You can add a CAN Keyboard, giving between 4 and 15 buttons, wireless wheels giving up to 8 buttons and 2 rotary inputs, and RIO modules, which can give 8 high or low inputs and 11 low-only inputs.
