Aim SmartyCam 7-Pin External Power Cable, ECU CAN & Integrated Microphone
Power Your System
The Aim SmartyCam ECU Harness provides a direct power supply to the camera with an integrated microphone to improve sound quality from your SmartyCam footage. The cable is available in 2 or 4 metre lengths and is compatible with the Aim SmartyCam 3 & 4 Corsa, 3 GP and 2.2 GP/GP HD.
Why Choose the SmartyCam Microphone Power Cable
The Aim SmartyCam 7-Pin External Power Cable, ECU CAN & Integrated Microphone is ideal if you want the reassurance of having your SmartyCam powered from your vehicle's 12V system with improved audio quality. It features CAN high and CAN low connection inputs for the ECU to suit a variety of motorsport setups.
Please Note: This connection cable is not required if you are connecting the SmartyCam to a logger or dash, as the power will be supplied to the camera through the CAN connection.
7-Pin Power, ECU CAN & Integrated Microphone Cable
