    €0,00 EUR
    Aim SmartyCam GP U Bolt Mount for Recording Box - AimShop.com
    SM-UB-GP-R
    In stock, ready to ship
    €93,95 EUR
    €93,95 EUR
    Aim SmartyCam U Bolt Mount For Recording Box 2.1, 2.2 & 3
    The SmartyCam GP HD can be installed using the GP HD U bolt mount. It is suitable for SmartyCam GP 2.1, 2.2 & 3.
    Ball & socket adjustment system
    Suitable for 0.5 to 1.2" bar, roll cage, railing
    SmartyCam 2.1, 2.2 & 3 Compatible
    SmartyCam GP Compatible
    Aim SmartyCam GP U Bolt Mount For Recording Box
    The Aim SmartyCam GP U bolt mount is used for mounting the SmartyCam GP 2.1, 2.2 & 3. The mount is designed to mount to a roll bar, railing or tube that have a diameter of between 0.5 to 1.2 inches.
    The U bolt clamp has a unique ball and socket system which has been designed to withstand the rigours of motorsport.
    The mount is adjustable so you can put the camera in the optimal position, tighten up the mount to secure the camera in position.
    U Bolt Mount
    Securely attaches to any roll bar, railing or tube with a diameter of 0.5 to 1.2".
    • For use with SmartyCam GP 2.1, 2.2 & 3
    • Arm height 90mm ( 3.54 inches )
    Aim SmartyCam GP HD U Bolt Mount For Recording Box
    • U bolt
    • 90mm arm
    • Clamp base with ball
    • Mounting bracket
    • Locknuts
    • Washers and screws
    Technical Sheet Race Studio 3
