Aim SmartyCam GP U Bolt Mount for Recording Box
Mount Your System
The SmartyCam U Bolt Mount is used for mounting the SmartyCam GP recording box system to a vehicle’s roll bar, railing or tube that has a diameter between 0.5 and 1.2 inches. It is compatible with the SmartyCam GP 2.1, 2.2 & 3 models, including the GP Pro.
Why Choose the SmartyCam Recording Box U Bolt Mount
The Aim SmartyCam U Bolt Mount is used to secure a SmartyCam GP recording box in a convenient location on a roll bar, railing or tube. The mount is easy to set up; simply attach the U bolt to the vehicle, and secure using the lock nuts for a secure fit. The ball and socket system allows you to easily adjust where the recording box sits for optimum positioning and has been designed to withstand the rigours of motorsport.
