    €0,00 EUR
    Aim SmartyCam Suction Cup Mount - AimShop.com
    SM-WM
    In stock, ready to ship
    €70,95 EUR
    Product Image
    €70,95 EUR
    Aim SmartyCam HD 2.1 & SmartyCam 3 Suction Cup Mount
    The SmartyCam can be installed using the suction cup mount. It is suitable for SmartyCam HD 2.1 & SmartyCam 3 Sport and Corsa models.
    Quick and easy to secure
    Mounts to a windscreen or flat surface
    Easy to move between vehicles
    SmartyCam HD 2.1 Compatible
    SmartyCam 3 Sport Compatible
    SmartyCam 3 Corsa Compatible
    The suction cup mount for the Aim SmartyCam is adjustable and holds securely to your windscreen, window or any other flat surface such as a motorcycle fuel tank.
    Mounting your SmartyCam is quick and easy. It can be easily positioned as to not get in the driver's way.
    Please Note: This bracket is only suitable for the SmartyCam HD 2.1 & SmartyCam 3
    Suction Cup Mount
    Securely attaches to any of your windscreens.
    Includes all the fixture and fittings.
    • For use with SmartyCam HD 2.1 & SmartyCam 3
    • Arm height 160mm ( 6.30 inches)
    • 1 suction cup
    • Clamp base with ball
    • 160mm single ball arm
    • 1 ball head
    • 1 washer diameter 17.7mm, thickness 1.5mm, hole 6mm
    Technical sheet Race Studio 3
