    €0,00 EUR
    Aim Solo 2 Dash / Steering Wheel Mount - AimShop.com
    UP-SOLO2
    €20,95 EUR
    €20,95 EUR
    AiM Solo 2 Dash / Steering Wheel Mount
    The Solo 2 dash/steering wheel mount is an easy and permanent fixture for mounting your Solo 2.
    Solo 2 dash/steering wheel mount 2mm thick stainless steel
    Solo 2 / Solo 2 DL Spare Backing Plate
    The Solo 2 dash/steering wheel mount is ideal if you want a permanent and easy fixture.
    2mm in raw stainless steel
    Other options are available to assist with this product, see the accessories tab for more options.
    • Dash/steering wheel mount
    • 2mm raw stainless steel
    • Solo 2 dash/steering wheel mount
