Upgrade your motocross setup with one of the best motocross lap timers in the industry — the Solo 2 DL Track Day Kit. Now available as a plug & play unit, display instant speed, timing splits, live data and predictive lap times on a high-contrast display with an accuracy of up to two-hundredths of a second, all specific to your bike model, just plug it in and go! See your exact riding line, compare it to optimal lines for faster lap times, track your bike’s movements and provide detailed data on acceleration, braking, and cornering forces. Do all of this and more with direct ECU data logging for instant, trackside, or post-race analysis with all your logged performance data.
The kit comes with a cable to connect the Solo 2 DL to your bike, relaying all vital ECU information. The cable is specific to your bike model.
Plug & play is currently available for the following bike models:
  • TM Racing
  • GET GP1 & GET Power
  • Suzuki
  • Microtec M222
  • Microtec M206
  • Honda
Please select your model before adding the Solo 2 DL Plug & Play Kit to your cart.
Why Choose the MX Solo 2 DL Track Day Lap Timer Kit
Building on the features of the Aim Solo 2 model, the Solo 2 DL MX lap timer connects directly to your bike’s ECU to record vital engine data, without the need for complex wiring. Compatible with a wide range of motorsport applications and bike ECUs, the Solo 2 DL is a versatile tool for helping motorsport professionals monitor and improve their performance in any motorsport discipline.
The Solo 2 DL has a sharp, high-contrast display which helps drivers easily identify the data displayed on screen, as well as 8 different backlight colours.
With thousands of pre-loaded worldwide track maps, the motocross lap timer automatically recognises your position on the track as soon as it's switched on. Once you start to drive, it automatically recognises the start line coordinates of the track and starts sampling lap times every time you go past.
Whether it's used for motocross, supercross, or enduro, the Solo 2 DL Kit allows you to create a new temporary or permanent track layout too. Even if there is no track already, the device will create one for you.
To take your data one step further, the Aim Solo 2 DL seamlessly connects to Aim SmartyCams and a variety of MX sensors to increase your data performance and enhance your analysis with the added visuals and overlays, as well as additional sensor information.
  • Display: Graphical LCD
Integrated Track Database
  • Over 4,000 worldwide
  • Wi-Fi Connection: Yes
  • GPS: 25Hz
  • External Power: 9-15V
  • Memory: 4GB
SKU: SOLO2
Pinouts
  • Solo 2 DL
  • Power Cable with AC Adapter
  • Your Chosen Connection Cable
Solo 2 DL Tech Sheet
Solo 2 DL User Guide
