Mount Your System
The Aim Weld-On Tab is a 3mm mild steel tab that has been designed to be welded onto a motorsport chassis or steering column. The Weld-On Tab provides a secure and permanent mounting point for Aim products like dashes, lap timers, keypads or shift light modules. It is commonly used with the 90-Degree Bolt-On Dash Bracket for easy installation and visibility of the dash.
  • Weld-on tab for dash display
  • 3mm mild steel
SKU: UP-TAB
