Motorsport Steering Wheel Plate
Race faster, harder and safer with push button controls at your fingertips. The Carbon 10 Button Wireless Motorsport Steering Wheel Plate combines minimum driver distraction with maximum ease of use.
Please Note: This product is not manufactured by Aim and is sourced from a third-party supplier.
Why Choose the 10 Button Steering Wheel Plate
The 10-channel wireless system allows you to have push button controls at your fingertips, whether you have a detachable steering wheel or would like to avoid the need for an unreliable coiled wire connection from your steering wheel to the dashboard. The plate has a carbon finish for superior durability at a fraction of the weight of other systems.
Digital Push Buttons & Rotary Switches
Wirelessly implemented, the in-vehicle commands are executed in a fraction of the time with 8 digital push buttons and two 12-position rotary switches, ideal for features such as traction control settings or for engine mapping.
The steering wheel plate is lightweight and integrates with most CAN devices, including dashboards, ECUs, PDUs and dataloggers, and has been tested to withstand the harshest EMI that can be generated within your car.
Battery Life
The 10 Channel Wireless Steering Wheel Plate has a standard CR2 lithium battery with a guaranteed life of 3 years or 50,000 miles, so you don't have to worry about the battery going flat.
The battery voltage is regularly transmitted to the CAN receiver with the intelligent system, and then forwarded to the Aim device that gives you around 30 days notice if the battery needs to be replaced.
Using our PDM systems and Race Studio 3 software will allow you to completely control the behaviour of the momentary push buttons to act as simple latching switches or more complex management.
Optional Stickers
Upgrade your wheel plate with adhesive stickers; pre-cut, hard-wearing and professionally printed. They are easy to apply and add a professional finish to your wheel plate.
Please Note: Images showing the steering wheel are for illustrative purposes only. The steering wheel is not included. The stickers are also for visual display to show how the wheel plate could look. Please see the accessories tab to purchase stickers.
Button Plate Front
  • Matt black, carbon
  • Dimensions: 176 x 154mm
Battery
  • Housing: ABS-UL94-VO
  • Dimensions: 54 x 38 x 23mm external
  • CR2 lithium battery
  • 50,000 miles of active use
  • Push Buttons: IP67 waterproof
  • Assembly: 10-channel, 285g
SKU: RBI-CWW-10
10 Button Carbon Plate User Guide
Wireless Plate CAN Protocol
