    €0,00 EUR
    Deutsch Male & Female DT Plug & Pins Including Wedge Lock - AimShop.com
    P-DT
    €6,95 EUR
    €6,95 EUR
    Deutsch Male & Female DT Plug & Pins including Wedge Lock
    The Deutsch Male & Female DT Plug & Pins, including wedge lock, are designed for cable to cable connection. The seals provide a robust seal with a high degree of environmental protection.
    Male & Female DT plugs Pins & wedge lock
    2 to 12 way options
    Safe, versatile and reliable, the DT plug connector housings are made from thermoplastic, ideal for automotive applications.
    The plug & pins are suited for applications that require a secure & reliable connector in harsh environments, like under the hood of your car, transmission tunnels and other areas that need secure connections in both power and signal.
    • Tactile and audible connector mating
    • Rugged thermoplastic connector housing
    • Hand insertable/removable connects
    • Operating temperature range: -55 to +125°C
    • Positive contact retention
    • 1 x DT Deutsch plug, pins, wedge lock
