Link G4X AtomX WireIn ECU
The Link G4X AtomX is an entry-level wirein ECU (engine control unit) for automotive applications. The AtomX ECU has expanded data logging and uses the same microcontroller as the entire G4X range. The processing unit is more responsive and has higher bandwidth than its G4+ Atom II predecessor.
G4X features 8x faster communication speed, allowing you to download logs 8x faster and push all the logging quickly up to a new and improved PCLink — available for download in the downloads tab.
Why Choose the Link G4X AtomX ECU
The Link G4X AtomX ECU can control up to 2 rotors or 4 cylinders with sequential injection and direct spark, or up to 8 cylinders using batch fire. Now featuring Knock Control, this makes the Link G4X AtomX ECU ideal for naturally aspirated engines that just need a re-tune and don't need all the extra sensors and features that come with higher-level Link ECUs.
Please Note: Requires "A" loom.
Suitable AtomX Applications
The compact Link G4X AtomX ECU is ideal for:
- 1-12 Cylinder Distributed
- 2-8 Cylinder Wasted Spark
- 1-4 Cylinder Direct Spark
- Odd Fire Engines
- 2-Stroke Engines
- Configurable Firing Order
- Configurable TDC Points (for odd fire)
G4X AtomX ECU & Bracket
USB Tuning Cable
Videos
G4X AtomX Overview
