    €0,00 EUR
    Link CAN Lambda - AimShop.com
    Accurate Lambda Measurement
    Wideband Bosch LSU 4.9 Sensor
    CAN Data Transmission
    Aftermarket ECU Compatible
    CANLAM
    Link CAN Lambda Kit
    €260,95 EUR
    Link CAN Lambda Kit
    €260,95 EUR
    Link CAN Lambda
    Link’s CAN Lambda is an easy to use CAN module that provides digital wideband sensor control via CAN bus and is compatible with leading aftermarket ECUs.
    If using the CAN Lambda with a G4+/G4X PlugIn ECU use a Link CANPCB cable to access the CAN port on the PlugIn PCB and a Link CANF field insertable CAN plug.
    Please note proper CAN protocol must be followed.
    The CAN-Lambda’s ability to measure the proportion of oxygen in exhaust gases makes it an essential tool for accurately tuning fuel mixtures as well as allowing your ECU to make tuning adjustments
    on the fly.
    Being fully digital the CAN Lambda’s powerful LSU 4.9 sensor will eliminate any loss of signal, risk, delays and errors that analogue alternatives cause. The CAN-Lambda never requires free-air calibration.
    Dimensions
    Enclosure 60 x 26 x 15mm
    Lead length 170mm
    Weight 70g
    Input Voltage
    Controller 7.5 - 20 V
    Sensor 10.8 - 16.5 V
    Input Current
    Controller 100 mA
    Sensor Heater 8 A
    Operating Temp -20 - 100 deg.C
    Sensor Bosch LSU4.9
    Sensing Range 0.67 - 10 lambda
    CAN Frequency 1Mb/s,500kb/s,250kb/s,125kb/s
    Link CAN Lambda
    • CAN-Lambda Device
    • Bosch LSU 4.9 Sensor
    • Deutsch 4-way Connector Kit
    • 02 Bung and Plug
    • 2 Large Stickers
    • 2 Small Stickers
    • Quick Start Guide
