    €0,00 EUR
    Link Honda CIVICLink - #HC96X PlugIn ECU - AimShop.com
    HC96X
    €1.062,95 EUR
    €1.062,95 EUR
    Designed for the 1996-1998 Honda B16 and B18 engine. All models that use the Honda “OBD2A” ECU.
    Onboard MAP sensor not included
    Suitable Applications:
    ACURA: 98-99 CL & 00-01
    Integra LS/GS/GS-R/Type-R
    HONDA: 98-02 Accord DX/LX/EX
    99-00 Civic DX/LX/EX/Si
    PlugIn Key Features:
    Sequential fuel delivery
    OEM idle hardware supported
    CAN port
    USB tuning cable included
    Staged injection
    Knock with "windowing"
    I/O Expansion Options:
    Expansion connector 1
    Gnd Sensor Ground Only
    Volt 5 Analog 0-5V input
    Volt 6 Analog 0-5V input
    Aux 7 Auxiliary Output
    Aux 8 Auxiliary Output
    Volt 7 Analog 0-5V input
    Temp 3 Temperature sensor input
    Expansion connector 2
    Ign 5 Ignition 5 Auxiliary Output
    DI 9 Digital Input
    DI 10 Digital Input
    Volt 8 Analog 0-5V input
    Volt 9 Analog 0-5V input
    • G4X PlugIn ECU
    • Stickers
