    €0,00 EUR
    Link KnockBlock G4+ tuning tool for engine knock detection and tuning calibration
    Link KnockBlock G4+ tuning tool by Link for engine knock detection and calibration setup
    Link KnockBlock G4+ tuning tool by Link, shown in black with compact handheld design
    Link KnockBlock G4+ tuning tool by Link for engine knock detection and tuning support
    G4-KB
    Link KnockBlock G4+ - #KNB
    €485,95 EUR
    €485,95 EUR
    The G4+ KnockBlock is an essential tool for tuning and can aid in the early detection of incorrect ignition timing, lean air/fuel mixtures and mechanical issues. It is used with earbuds, headphones or noise-cancelling earmuffs and features special filtering to allow you to listen in and detect knock early.
    Features
    Listen to one or two knock sensors
    Special filtering design improves the signal to noise ratio
    Can be used with ear-buds, headphones or noise-cancelling ear muffs
    Long-life lithium rechargeable battery
    Rugged CNC aluminium enclosure
    Flying lead headphones connector
    Can be used with all OEM knock sensors
    Can be used to interface directly to a laptop for the recording of engine noise or knock sensor frequency analysis (using PCLink G4+)
    Please Note: Headphones with their own noise filtering may be unsuitable for use with the KnockBlock.
    Operating
    Install the knock sensor/s in a suitable location on the engine (typically on a solid mounting point on the block near the cylinder head)
    If only using one sensor, leave the unused sensor cable disconnected
    Turn the volume control clockwise until it clicks. The LED indicator will turn blue when the KnockBlock is operating
    Turn the volume to the minimum setting (most anti-clockwise)
    Connect headphones to the 3.5mm audio jack
    Run the engine and carefully increase the volume (clockwise) until engine mechanical noise can be heard. Adjust to a comfortable listening volume
    Charging
    Turn off the KnockBlock by turning the volume control anti-clockwise until it clicks
    Connect the USB charging cable to the KnockBlock’s Mini USB connector. Can be charged from any standard USB charger PC, laptop, car or cell phone charger (2.1A at 5V max)
    The LED indicator will show red while charging. When the indicator turns off the battery is fully charged
    Charge the G4+ KnockBlock after use and before storage
    Charging
    • G4+ KnockBlock
    • 2 Sensor Looms (attached)
    • 1 Headphone Loom (attached)
    • Quick Start Guide
    • 1 USB cable mini
    • 2 Bosch type doughnut OEM knock sensors
    • 2 small Link Engine Management stickers
