Second-Life Aim 10" TFT PDM Dash Display with Road Icons
Advanced PDM Display
The 10" PDM display with road icons is one of the most widely used PDM displays on roads around the world. It’s suitable for use as a replacement unit for those supplied with the Aim PDM kits or an upgrade for PDM kits that do not include a dash display.
Why Choose the 10” PDM Display
The 10" PDM display is a TFT dash display suitable for replacing all of the dashboard gauges and warning lamps. The displays are available in 5”, 6" or 10" versions and with both "Road" or "Race" icon options. All versions have fully user-configurable displays and offer a range of layouts.
Please Note: The 10" dash display is ONLY for use with Aim PDM kits and can not be used as a stand-alone dash display.
Power Distribution Modules
The dash has a 10" TFT high contrast colour display. The visual quality is optimised by the ambient light sensor, which keeps the backlight at the best brightness levels.
Pre-Configured Pages
The Aim PDM 10" Display can show the RPM scale and all the data you need, like speed, water temperature and oil pressure, lap times and much more. You can customise pages to suit your requirements, including up to four additional fields. Define what data is shown with the end of scale and measure units. Swapping between the pages is easy; just use the push buttons.
Integrate a Reverse Camera
- All channels
- ECU drivers
- Math channels
- Display pages
- Digital outputs
- Alarms
- Shift lights
- Expansions
Add extra devices to your system to give additional data to improve your driving performance, such as a GPS Module, SmartyCams, Lambda Controller, Formula Steering Wheel, TPMS System and Keypads.
The 10" road display also doubles up as a reversing mirror using a separately available camera—ideal for cars with limited rear vision. You can add up to 2 cameras for both front and rear views. The camera is sold separately.
10" PDM Dash Display with Road Icons
| Specs |
PDM 5" Display
PDM 6" Display
PDM 10" Display
What are the best applications for the 10" PDM display with road icons?
The 10" PDM display with road icons is best suited to road-registered performance cars and track-day vehicles that require street-legal functionality in larger cockpits.
- Configure via Race Studio 3 through USB connection, where you can map CAN data, define power output logic and customise the display. Please see our PDM user guides in the PDM product pages' downloads tab for more information.
- Connect the PDM-compatible display to the PDM unit with an LVDS cable (4-pin Rosenberger connector).
- Mount the display using genuine Aim PDM dash brackets available in 2 sizes: a bracket for 5/6" displays or a bracket for 10" displays, in a clear line of sight for the driver.
Which alarms can be set on the 10" PDM display?
The Aim 10" PDM display features fully customisable alarms that are configurable to trigger by almost any sensor, ECU value or system status via Race Studio 3. Alarms can be displayed as on-screen text, pop-up messages and visual alerts using the 10 RGB LEDs and configurable road icons.
Although the shift lights are designed for optimum gear shifting, you can use a math channel to customise them to what you want them to be. For example, a math channel can be used to multiply GPS speed by 1 and have the output as an engine RPM. Using that math channel as the shift light RPM, you have now got speed on the shift lights.
