    €0,00 EUR
    Second-Life Taipan ECU - AimShop.com
    €453,95 EUR
    This site is protected by hCaptcha and the hCaptcha Privacy Policy and Terms of Service apply.
    This Taipan ECU comes back to us as a trade-in, fully equipped and ready to take on its second life. The ECU is in full working order and has been meticulously checked by our technicians.
    Aim Taipan ECU Plug & Play Engine Control Unit
    Taipan is the brand-new aftermarket plug & play ECU created by Aim, exclusively designed for off-road bikes. Thanks to its high technology 32-bit core, it represents an important step forward to improve the performance of your bike, without sacrificing reliability and smoothness.
    This specific Taipan ECU is unprogrammed. It can be configured for any brand or model bike you require. You will need the UC Bridge Tuner to enable this process.
    Once the unprogrammed Taipan ECU has been configured with a dedicated brand or model it can not be changed. You will be able to modify the maps written into the ECU but the brand or model which has been configured can not be changed.
    Traction Control
    Traction Control Strategy
    Launch Control
    High Technology 32-bit Core
    Engine control requires precision. At 20,000 RPM the TaipanECU guarantees the precision of 1/10 of the degree: this means an accuracy within 0.8 uses for turning the spark ON!
    Tuner License :
    This is the Tuner that is required to configure the unprogrammed Taipan ECU.
    *Please Note: For information regarding the UC-Bridge Tuner, please contact one of our Aim technical team for further information.
    Taipan ECU Connections
    The Taipan ECU has 4 connectors :
    2nd CAN Connector - Connect to the UC Bridge, to communicate with the PC.
    3rd Connector - Connect to spare analogue inputs and a possible second injector.
    Below shows a functional diagram of products that can be added to the Taipan ECU:
    • One low side driver (1 A)
    • Power consumption 150 mA
    • n. 1 33 pin male Connector
    • Body: PA6 + 30% glass fiber
    • Waterproof: IP67
    • Weight: 260g
    • ECU Taipan Control Unit
    Video
    User Guide Tuning Manual Technical sheet Race Studio 3 Spark Tuning Software
    Use our 24/7 AI chat support, or call us from Monday to Friday between 09:00 and 17:00 BST
    Next-day delivery options available, and same-day shipping guarantee when you order before 15:00 BST Monday - Friday
