Suzuki GSX-R Aim Solo 2 & Solo 2 DL Motorcycle Bracket
Choose Accessories
Mount Your System
The Suzuki Motorcycle Bracket has been specifically designed to provide a simple and secure mounting solution for Aim Solo 2 and Solo 2 DL Lap Timers. The bracket is compatible with Suzuki GSX-R 600 (from 2004-2023) and GSX-R 750 (from 2004-2017) motorcycles.
Why Choose the Aim Solo 2/2 DL Motorcycle Bracket
The Aim Solo 2/2 DL Motorcycle Bracket ensures your Solo 2 GPS Lap Timer can be securely mounted on your Suzuki GSZ-R motorcycle. Supplied with all the necessary hardware, it provides a quick and stress-free installation, so you can accurately track and monitor your laps with ease.
Plug & Play Cable
A separately sold plug & play cable is also available for the following Suzuki motorcycle models:
- GSX-R 600
- GSX-R 750
- GSX-R 1000
- GSX-R 1000 L7
- GSX-R 1300 Hayabusa Gen.2
If you are unsure whether this bracket will fit your motorcycle, don't hesitate to contact our team.
Suzuki Solo 2/2 DL Bracket
x1 Round Head Allen Screw M8x45mm
x2 Flat Head Allen Screws M4x10mm
x1 Toothed Washer
x1 Rubber Dowel
