Adaptateur de capteur de pression de frein avec double boulon banjo M10
Brake Pressure Sensor Adaptor
This brake pressure sensor adaptor kit allows you to easily install a pressure sensor into your braking system using a double banjo bolt connection. Designed for M10 x 1.0 thread compatibility, it provides a clean and reliable solution for adding a brake pressure sensor without the need for additional fittings or modifications.
Why Choose the Brake Pressure Sensor Adaptor
With a compact design, the brake pressure sensor adaptor with a double banjo bolt fits neatly into existing hydraulic systems and has a high-quality construction for durability and leak-free performance. The full system is ideal for straightforward installation and is fully compatible with M10 x 1.0 thread brake pressure sensors.
Please Note: Brake pressure sensor is sold separately and is not included.
Adaptateur de capteur de pression de freinage
Boulon banjo double
Rondelles
