Aim Câble de raccordement mâle-femelle 4 broches 712-719
Connect Your System
The Aim 712-719 patch lead is a durable extension cable with 4-pin male and female connectors designed for connecting sensors or expanding existing wiring in your Aim data system. Featuring quick and easy to use secure push-on connectors, it always ensures reliable signal transmission.
Why Choose the Aim 712-719 Patch Lead
The Aim 712-719 patch lead simplifies installation and setup, allowing easy connection between sensors, expansion hubs, or modules without complex rewiring. It's ideal for clean, organised sensor layouts. The 4-pin male to female lead is available in multiple lengths (0.5 m, 1m, 1.5m, 2m, 2.5m, 3m, 3.5m, and 4m) and is compatible with Aim systems such as EVO4/EVO4S loggers and Channel Expansion devices.
Essentially, the 712-719 patch lead is used to extend your connections or integrate additional modules, ensuring flexibility and reliability across your Aim racing setup.
712-719 Cordon de brassage mâle à femelle
