Passer au contenu
Connexion
Rechercher
Rechercher Connexion Panier 0
Panier
Votre panier est vide.
  • Continuer les achats
    Sous-total
    Voir le panier
    Rechercher
    Aim 712 Male 7-Pin to 712 Male 5-Pin SmartyCam CAN Cable - AimShop.com
    712-712 Patch Lead
    5-Pin to 7-Pin Male
    High-Quality Connectors
    Various Sizes Available
    SM-CAN
    En stock, prêt à être expédié
    £40.00
    712-712 Patch Lead
    5-Pin to 7-Pin Male
    • Partager sur Facebook
    • Partager sur WhatsApp
    • Partager par Email
    • Email Partager par Email
    £40.00
    AiM SmartyCam 2.1 HD CAN Harness
    The AiM CAN harness is required to connect the SmartyCam 2.1  HD.
    Suitable for 2.1 HD CAN harness
    Available in  2m and 4m
    The AiM CAN harness for the SmartyCam 2.1 HD SmartyCam camera. This lead is required to connect the SmartyCam to an AiM dash/logger or data hub.
    712-5 pin male to 712-7 pin male
    High-quality cables and connectors
    Provides you with flexibility for better SmartyCam location
    • CAN Harness
    • 712 5 pin male to 712 7 pin male
    • Suitable for SmartyCam 2.1 HD
    • 1 x SmartyCam 2.1 HD CAN Cable
