Aim 712 Hommes & Bouchons de reliure femelles
Connect Your System
The Aim 712 Binder Connectors are robust, reliable and perfect for shortening cables, making custom length cables, or adding additional sensors or extension cables to your Aim system.
Why Choose the Aim 712 Binder Plug Connector
The Aim 712 Binder Plug is a high-quality metal connector available in male or female, with 3, 4 or 5-pin options to suit your motorsport setup. The 712 Binder Plug is the ideal accessory for replacing existing connectors or adapting the length of the cable.
Chosen 712 Binder Plug
