Passer au contenu
Connexion
Rechercher
Rechercher Connexion Panier 0
Panier
Votre panier est vide.
  • Continuer les achats
    Sous-total
    Voir le panier
    Rechercher
    Aim 719 (Plastic) Binder Plug - AimShop.com
    P-719
    £10.00
    • Partager sur Facebook
    • Partager sur WhatsApp
    • Partager par Email
    • Email Partager par Email
    £10.00
    The Aim 719 binder plug 4 pin is ideal for replacing damaged plugs or for adding additional sensors or extension cables to your Aim system.
    Key Features:
    Suitable for Aim sensors 4 pin  plastic Binder
    Ideal for adding to your system
    The Aim 719 binder plug 4 pin is ideal for replacing damaged plugs or for when adding additional sensors or extension cables to your Aim system. The plug has four pins.
    Ideal for replacing broken plugs or when adding sensors to your Aim system.
    Fits Aim 719 cables and sensors
    • 719 Plastic Binder Plug
    • 1 x 719 Plastic Binder Plug
