Aim Connecteur Deutsch femelle & Broches pour la série MX
Deutsch Connector & Pins
Available in 22 or 37 pin options, the Aim Female Deutsch Connector is suitable for use with the Aim MX Series dashes as a replacement, as spares or as part of building a wiring loom. It comes with the selected pin quantity, the Female Deutsch Connector and a plastic tool to install the pins
Chosen Plug & Pins Kit
