Passer au contenu
Connexion
Rechercher
Rechercher Connexion Panier 0
Panier
Votre panier est vide.
  • Continuer les achats
    Sous-total
    Voir le panier
    Rechercher
    Aim OTK Kart Throttle Position Sensor Magnet Holder - AimShop.com
    AiM OTK Magnet Holder For Throttle Position Sensor - AimShop.com
    For OTK Karts
    B-OTK-T-MH
    En stock, prêt à être expédié
    £25.00
    For OTK Karts
    • Partager sur Facebook
    • Partager sur WhatsApp
    • Partager par Email
    • Email Partager par Email
    £25.00
    This holder is specific for the magnet used in the AiM kart throttle position sensor kit and is designed for use on OTK karts.
    Suits AiM throttle position sensor kit Specific OTK karts
    Fits to the throttle cable
    This holder is specific for the magnet used in the AiM kart throttle position sensor kit and is designed for use on OTK karts. The holder allows the magnet to be fitted to the throttle cable instead of the pedal. An OTK cable holder for the sensor is available to purchase separately.
    • Suits AiM Throttle Position Sensor Kit
    • Suitable for OTK Karts
    • Fits to throttle cable
    • 1 x Magnet Holder for Throttle Position Sensor
