Aim Support magnétique pour capteur de position du papillon OTK Kart
Mount Your System
The Aim Throttle Position Sensor Magnet Holder is a mounting bracket made specifically for use with the throttle position sensor kit, designed for OTK karts.
Why Choose the Aim Throttle Position Sensor Magnet Holder
The Aim Throttle Position Sensor Magnet Holder is designed and engineered to hold the brake position sensor and cable securely in place for accurate positioning and stable alignment of the sensor relative to the magnet. It secures the sensor directly onto the throttle cable (rather than onto the pedal) by clamping to the throttle cable’s sleeve. The holder is the same as the one supplied in the non-contact throttle position kit, making it ideal for use as a spare or replacement. An OTK sensor bracket is also available to purchase separately.
Please Note: The magnet is not included.
Support magnétique de position du papillon
