What is the Aim MX Strada Logger
The Aim MX Strada logger is a compact data recording module, connected via CAN bus, that will upgrade and turn any base MX Strada (MXS, MXP, MXG or MXT) into a complete data logger.
Why Choose the Aim MX Strada Logger
The MX Strada logger will record all the data from your practice sessions or race onto the data logger and prepare it to be downloaded to Race Studio 3 software for further analysis. This allows you to review and analyse your data to help improve driving technique and identify possible improvements in vehicle setup, all of which could take seconds off lap times.
Data will be saved on an SD card (supports up to 32GB memory cards) and stored in the logger memory. You can remove the memory card during a pit stop or with the engine running, so if you are in an endurance race or an extended test session, you can analyse your recorded data whilst you are still on track. The MX Strada logger also features a front LED that shows its status: recording/firmware status.
Please Note: SD cards are not included with the MX Strada logger.
  • Max Power Ponsumption: 50mA
  • Cable Length: 20cm/40cm
  • SD Card: Supports up to 32GB (not included)
  • Dimensions: 55.5 x 78.3 x 18mm
  • Weight: 103g
SKU: MX-TL-B-MC
Aim MX Strada Logger dimension diagram
Fiche technique de l'enregistreur Strada
