Aim Câble de téléchargement MXL avec prise jack 3,5 mm
Jack - USB Download Cable
The Aim Jack Plug - USB Download Cable provides a quick and reliable connection between your Aim MXL dash and your PC, allowing fast data transfer and system configuration through Race Studio 3 software. Featuring a 3.5mm jack plug and a standard USB interface, this cable delivers a secure connection with no adapters or wiring required.
Why Choose the Aim USB Download Cable
The Aim Jack Plug to USB Download Cable is the ideal solution for downloading logged data, providing the perfect compatibility and reliability expected from Aim. Fully compatible with Aim MXL dash systems, it ensures a clean, direct link between your MXL and your PC for accurate data analysis.
Jack Plug to USB Cable
