Aim Câble d'alimentation externe MyChron 12V
12V External Power Cable
The Aim MyChron 12V External Power Cable is designed to provide a stable and reliable power source for MyChron 4, MyChron 5 and MyChron 6 Lap Timers. It allows you to connect the lap timer/data logger directly to the vehicle’s 12V battery from the EXP/CAN port on the back of the MyChron unit, ensuring uninterrupted operation during long sessions.
Why Choose the Aim MyChron External Power Cable
The Aim MyChron 12V External Power Cable can be used to keep your MyChron display powered without relying solely on internal batteries - ideal for teams looking for reliability, consistency, and extended runtime in competitive karting environments.
The MyChron Power Cable features a durable 5-pin 712 male connector on one end and spade terminals on the other for simple and secure connection to your kart’s electrical system. Its design minimises voltage drop and maintains consistent data logging performance.
