Aim Câble patch MyChron5 S 2T avec double prise TR 719
Double Temperature Sensor Cable
The Aim MyChron 2T double temperature sensor split cable allows 2 separate 719-type temperature sensors to share the same input on the MyChron 2T Lap Timer. One end features a 7-pin 712 male binder connector, and the other splits into two 4-pin 719 female binder connectors. This design enables you to feed 2 different temperature sensors into your MyChron 2T from a single port, maintaining strong signal strength under race conditions.
Why Choose the Double Temperature Sensor Cable
The MyChron 2T Lap Timer (including the 4, 5, 5S and 6 models) supports 2 temperature channels but only has a single 7-pin 712 port. The double temperature sensor split cable bridges the gap by letting you connect both sensors easily. The cable is built with professional-quality leads and connectors to deliver dependable performance and long-lasting reliability.
Compatible Temperature Sensors
There are various temperature sensor combinations that can be used with this double patch lead. For example, the 719 connectors can fit 2 x Water Temperature Sensors, either 2 x M5 thread, 2 x M10 thread or one of each.
Temperature Sensor Cable - Double 719
