Aim Faisceau de câbles séparé MyChron 6 vers ACC3
Endless Karting Expansions
A versatile connection solution designed to help you get more from your MyChron system, with three harness options to suit different requirements. From essential sensor monitoring to more advanced setups, choose the configuration that best suits your karting needs.
Why Choose the MyChron to ACC3 Split Harness
The Aim MyChron 6 to ACC3 Split Harness connects your MyChron 6 or MyChron 6 2T to the ACC3, enabling the use of additional analogue sensors for engine monitoring, throttle position, brake pressure and more.
Available in three configurations to suit your setup, from a simple ACC3 connection to a more comprehensive solution with external power and CAN expansion.
Split Harness Options
Connects the ACC3 to your MyChron 6 or MyChron 6 2T, allowing additional analogue sensors to be used with your system.
MyChron 6 to ACC3 Split Harness With External Power
Provides the same ACC3 connection and analogue sensor functionality, with the addition of an external power connection.
MyChron 6 to ACC3 Split Harness With 4x CAN Multipliers & External Power
Combines the ACC3 connection with external power, four CAN Multipliers and CAN bus integration. This configuration enables additional compatible CAN accessories, including the LCU1S, SmartyCam 4 and tyre temperature systems, to be connected to your MyChron 6.
Compatibility Information
The ACC3 supports analogue sensor inputs only. The standard and external-power harnesses do not independently provide CAN expansion.
Connecting additional CAN accessories requires a suitable CAN Multiplier or Data Hub, as provided by the appropriate configuration.
J'ai choisi MyChron pour le harnais divisé ACC3
