Aim Support de cage de sécurité SmartyCam Mini
Mount Your System
The Aim SmartyCam Mini Roll Cage Mount has been specifically designed to hold and position SmartyCam cameras onto a roll bar tube. It is compatible with SmartyCam 2.1, 2.2, 3 & 4 Sport, Corsa or the older HD model.
Why Choose the SmartyCam Mini Roll Cage Mount
The Aim SmartyCam Mini Roll Cage Mount is made up of aluminium, with a black anodised finish and is specifically designed to withstand the rigours of motorsport use. The 2 jubilee clips allow for easy fitting of the camera to different roll cage tube diameters, and the clamp is available with standard or extended lengths.
Chosen Roll Cage Mount
Pinces Jubilé 44 mm & 55 mm
