Aim Câble de connexion Solo 2 DL/EVO4S pour Ducati Panigale V2 & V4 Euro5
Universal Motorcycle ECU Connection
The Aim Euro5 Plug & Play Cable allows you to connect Aim Data Loggers, such as the Solo 2 DL, ECULog or XLog, to the Euro5 connector found on most modern motorcycles built from 2021. The Euro5 Cable provides an easy plug & play connection to the motorcycle's ECU on one end, and uses a metal 712 screw-on binder connector with 7-pins on the other end, allowing ECU data to be logged.
Which Motorcycles are Compatible with the Euro5 Cable?
The Euro5 Cable is compatible with most motorcycle models from 2021 onwards, including Aprilia, BMW, Ducati, Honda, Husqvarna, Kawasaki, KTM, Suzuki, Triumph and Yamaha. If you are unsure whether the Euro5 ECU Cable will fit your motorcycle, don't hesitate to contact one of our team, either by email, phone or online chat.
Euro5 External Power Cable
