Upgrade your track day setup with one of the best motorcycle lap timers in the industry — the Solo 2 Motorcycle GPS Lap Timer. Equipped with an integrated GPS, built-in gyro, user-friendly interface and compatibility with session performance analysis software, the Solo 2 provides precise lap times, delta times and detailed telemetry for amateur and professional riders alike to optimise their performance and achieve their goals.
Why Choose the Motorcycle Track Day Solo 2 GPS Lap Timer
The Motorcycle Solo 2 Lap Timer includes a high-precision GPS and receives data from GPS and GLONASS satellite constellations. This allows the device to display instant speed, timing splits, live data and predictive lap times on its high-contrast display with an accuracy of two-hundredths of a second to help riders improve their performance on the track.
The improved GPS technology in the Solo 2 also provides better reliability from the predictive lap timing function so that you can see, in real time, how your current lap compares to your best lap. The LEDs are also configurable to give a visual indication of whether you are quicker or slower.
Accurate Lap Times
The Solo 2 Motorcycle Lap Timer features a 100Hz 6-axis inertial platform to calculate, show and record lap times, sector times, position & bike speed, with a sampling rate of up to 25Hz, and 3D acceleration & gyro.
Solo 2 lap timing features
Predictive Lap Timing
  • Best lap of the day
  • Best lap of the session
  • Previous lap
  • User reference lap
Showcase of the Solo 2 backlight colour options
The Solo 2 has a sharp, high-contrast display which helps riders easily identify the data displayed on screen, as well as 8 different backlight colours.
Thousands of pre-loaded worldwide track maps are available, the track day lap timer automatically recognises your position on the track as soon as it's switched on. Once you start to ride, it automatically recognises the start line coordinates of the track and starts sampling lap times every time you go past.
Whether it's used for point-to-point runs or a closed-loop track, the Solo 2 allows you to create a new temporary or permanent track layout too. Even if there is no track already, the device will create one for you.
Showcase of the Solo 2 sector timing feature
Lap Times & Sector Times
The Solo 2 features an internal, high precision, 25Hz, 4-constellation GPS receiver and an internal database including information about thousands of tracks all over the world: just switched 'On,' it automatically recognises the track and gets the information about the starting line position and the time zone.
The precision of the calculated lap times is 1/100 of second.
Extensive Track Database
The Solo 2 Motorcycle Lap Timer includes thousands of pre-loaded track maps worldwide. The lap timer automatically recognises your position on the track, recognises the start line, and starts sampling lap times every time you ride past.
Whatever discipline, the Solo 2 allows you to create a new temporary or permanent track layout too. Even if there is no track already, the device will create one for you.
Solo 2 Suction Cup, Rollcage & U Bolt Mounts
Mounting Options
A variety of Solo 2 mounts provides an easy installation for a wide range of vehicle types.
  • Display: Graphical LCD
Integrated Track Database
  • Over 4,000 worldwide
  • Wi-Fi Connection: Yes
  • GPS: 25Hz
  • External Power: 9-15V
  • Memory: 4GB
SKU: SOLO2-K1
  • Solo 2
  • Power Cable with Lighter Socket
  • Cable icon
    Wall Charger with AC Adapter
Solo 2 Tech Sheet
Solo 2 User Guide
Videos
Overview
Charger la vidéo: A walkthrough of the main features and functions of the Aim Solo 2 motorcycle lap timer.
Walkthrough
Charger la vidéo: An in-depth review of the main features and functions of the Aim Solo 2 motorcycle lap timer.
Race Studio
Charger la vidéo: In this episode, we explain how to get the most out of your Solo 2 data to maximise your performance using Race Studio.
What are the differences between the Solo 2 and the Solo 2 DL?
Although both the Solo 2 and Solo 2 DL record lap times, sector times, speed, track position and G-forces (from internal accelerometer), the Solo 2 DL provides even more advanced data logging:
  • ECU data (RPM, throttle position, brake pressure, coolant temp, etc.)
  • Connects to sensors and cameras, allowing for data overlays on video.
What is the best motorcycle lap timer?
The Solo 2 is ideal for motorcycle track days to monitor lap times and speed/position. The Solo 2 DL is best-suited to drivers and teams who want to connect directly to the motorcycle's ECU to record and monitor advanced engine and performance data to understand why seconds are being lost.
How do you power the Solo 2 motorcycle lap timer?
The Solo 2 has an internal rechargeable battery that powers the lap timer for 4-5 hours on average. The power cable can either be connected to the motorcycle's 12V system using the 5-pin power cable or it can be recharged externally using a mains charger.
Do I need a GPS lap timer?
If you're serious about improving consistency in your riding lap times and staying competitive on the track, then a dedicated lap timer with accurate GPS tracking is well-worth the investment.
How do I mount the Aim Solo 2 to my motorcycle, and does it come with mounting accessories?
The Aim Solo 2 comes with a universal mounting bracket, with optional accessories such as a suction cup, u bolt, or roll cage bracket. We also offer model-specific brackets for certain motorcycles for true compatibility. All mounting options provide a stable and vibration-resistant mounting solution, ensuring accurate data collection during your sessions.
How do I customise the display and LED shift lights on the Aim Solo 2?
Customising the display and LED shift lights on the Aim Solo 2 is straightforward. You can adjust settings directly on the device through its user interface. To do this:
  • Navigate to the "Settings" menu using the side buttons.
  • From there, you can choose various display options, such as switching between lap time, predictive lap timing, speed, and other data fields.
  • To customise the LED shift lights, go to the "Shift Light" setting, where you can set specific RPM thresholds for when the LEDs light up, or you can adjust their brightness and colour. These settings help you optimise performance by providing visual cues while driving.
For more detailed customisation, you can also make changes through the Race Studio 3 software, where additional options like screen layouts are available.
Aim Solo 2
  • 4GB Internal Memory
  • Automatic Track Recognition
  • Integrated GPS
  • Ten Configurable RGB LEDs
  • Wi-fi Connectability
  • GLONASS Receiver
  • Direct ECU Data Logging
  • Predictive Lap Timing
  • Choice of Connection
  • Integrated GPS
  • Graphical Display
  • Solo 2 DL
  • Choice of connection Cable
  • Solo 2
  • GPS: 25Hz
  • Memory: 4GB
  • GPS: 25Hz
  • Memory: 4GB
