Passer au contenu
Connexion
Rechercher
Rechercher Connexion Panier 0
Panier
Votre panier est vide.
  • Continuer les achats
    Sous-total
    Voir le panier
    Rechercher
    Aim Solo Spare Backing Plate - AimShop.com
    SOLO-BP
    En stock, prêt à être expédié
    £30.00
    • Partager sur Facebook
    • Partager sur WhatsApp
    • Partager par Email
    • Email Partager par Email
    £30.00
    The Aim spare backing plate is designed for mounting the Solo GPS Lap Timer.
    Key Features:
    Spare backing plate Suitable for Solo GPS lap timer
    The Aim spare backing plate to suit the Solo enables you to mount your Solo to most flat surfaces. The Solo has two large integrated magnets on the back that hold it in place, so you can simply install or remove it with ease.
    Standard original mount ideal for use as a spare.
    Mount onto flat surfaces
    • 1 Solo Backing Plate
    • 2 screws
    • 2 washers
    • 2 nuts
    • Solo Backing Plate
