Aim Canaux analogiques Taipan & Deuxième faisceau d'injection
Choose Accessories
Expand Your Data
The Aim Taipan Analogue Channels & Second Injection Harness is an optional cable that pairs with the Taipan ECU. It has a JST connector that connects with the Taipan ECU, then splits into a cable with 2 flying cables for the second injection and another cable with 3 flying wires for the analogue channels, with the full length being 2.5m.
Why Choose the Aim Taipan Analogue Channels & Second Injection Harness
The Aim Taipan Analogue Channels & Second Injection Harness is durable and convenient in size, so it can easily reach around your bike while remaining sleek and compact, making it ideal for any motocross setup. Typically, a motocross bike is limited to a single fuel injector, but the second injection wires within the harness allow you to add a second one. Essentially, the harness allows you to gather more detailed data or have a specific engine setup that requires these extra connections for better performance tuning and management.
Various Aim setups can be connected with the Taipan Analogue Channels & Second Injection Harness to monitor data and help get the results you want. Popular product combinations include devices like the Motocross Solo 2 DL, Handlebar Switch, UC Bridge and Taipan ECU.
Videos
