Raccord d'extrémité rose de remplacement pour potentiomètre
Suspension Potentiometer Fitting
Replacement/spare rose end suspension potentiometer fitting; ideal for measuring the displacement between two points using a sensor (the linear potentiometer) directly connected to the points of measure. The sensor is not included.
Why Choose a Replacement Potentiometer Rose End Fitting
The rose end fitting is an ideal replacement or spare fitting for Aim Suspension Potentiometers. It provides a secure and reliable connection to allow you to measure linear displacements like:
- Suspensions and spring cushions compression or extension.
- Steering column rotation is measured through the rack displacement.
- Shock and suspension travel.
- Ride height.
- Wing or spoiler deflection at speed.
Rose End Fitting
