Aim Capteur de pression d'huile 1/8 NPT 0–150 PSI
Oil Pressure Sensor 1/8 NPT 0–150 PSI
The Aim Pressure Sensor is suitable for oil, fuel and water pressure readings, reading pressures up to 150 PSI. This pressure sensor sits within the oil/fuel line, and measures exactly how much pressure passes through.
Why Choose the Aim Oil Pressure Sensor
The Aim 0-150 PSI Pressure Sensor is available in 1/8 NPT thread options and is fitted with a 4-pin 719 male binder connector to suit Aim loggers, dash loggers, lap timers and dash displays. Many aspects affect various engine pressures, so knowing your engine has the correct amount of pressure is paramount to longevity and performance.
If there is a pressure change, incorporating a pressure sensor into your setup will allow it to be detected and signalled to prevent the worst. You can see through live telemetry about what’s happening as the sensor turns the physical force of fluid pressure into a predictable electrical signal that can be monitored to protect your engine.
How the Oil Pressure Sensor Works
The Aim Oil Pressure Sensor is screwed directly into the engine block or oil gallery using its 1/8 NPT threaded fitting. Inside the sensor is a rugged internal component, typically a stainless steel diaphragm.
As the oil pump circulates oil through the engine, the force of the oil pushes against this diaphragm, causing it to flex. The sensor precisely measures this movement and converts it into an electrical voltage signal:
- Low Pressure (0 PSI): The sensor outputs a baseline voltage, typically 0.5 Volts (V).
- High Pressure (150 PSI): The sensor outputs its maximum voltage, typically 2.5 Volts (V).
This is a linear scale, meaning the voltage climbs steadily as the pressure rises. For example, if the oil pressure is exactly halfway (75 PSI), the voltage will also be halfway between the minimum and maximum (exactly 1.5V). This electrical signal is what the vehicle’s data logger or ECU (engine computer) records to ensure your engine stays properly lubricated.
The pressure sensor allows you to detect fluid and air pressures. It offers a high level of reliability and endurance and is protected against the high vibration, shock and high temperatures found in motorsport.
We also offer unterminated sensor that are designed to work seamlessly with Bosch, MoTeC, Cosworth, or other manufacturer hardware, making it easy for you to integrate the reliable and efficient Aim Pressure Sensors into any setup.
You can expand your system with a range of products from the ACC3 Analogue CAN Converter, Displays and Loggers, Data Hubs and more.
1/8 NPT 0-150 PSI Pressure Sensor
