Passer au contenu
Connexion
Rechercher
Rechercher Connexion Panier 0
Panier
Votre panier est vide.
  • Continuer les achats
    Sous-total
    Voir le panier
    Rechercher
    Deutsch Male & Female DTM Plug & Pins including Wedge Lock - AimShop.com
    P-DTM
    En stock, prêt à être expédié
    £8.00
    • Partager sur Facebook
    • Partager sur WhatsApp
    • Partager par Email
    • Email Partager par Email
    £8.00
    The Deutsch male & Female DTM Plug & Pins, including wedge lock, are ideal connectors for PDM use and are often used in engine compartments and transmission tunnels.
    Male & Female DTM plugs Pins & wedge lock
    2 to 12 way options
    The plug & pins are suited for applications that require a secure & reliable connector in harsh environments, like under the hood of your car, transmission tunnels and other areas that need secure connections in both power and signal.
    • Tactile and audible connector mating
    • Rugged thermoplastic connector housing
    • Hand insertable/removable connects
    • Operating temperature range: -55 to +125°C
    • Positive contact retention
    • 1 x DTM Deutsch plug, pins, wedge lock
