G5 Voodoo Neo 4
The next generation of engine management for many more engines.
The G5 Voodoo Neo 4 Can Run:
  • 6 cylinders port or direct injection and direct spark, or,
  • 4 cylinders with direct/port staged injection, and direct spark
The G5 Voodoo processing units are the perfect choice for professional level motorsport.
G5 Voodoo Neo Key Features
  • An all-new communications module: 10x faster USB speeds (from minutes down to seconds to download log files), Ethernet, and enhanced WiFi and GPS.
  • 1GB of onboard logging memory, double that of other Link ECUs.
  • Highly customisable IO, using 2 types of multi-purpose pins - Injection/Ignition/Aux pins and dual-purpose ADIO pins.
  • Dual onboard E-throttle, with H-bridges that now natively support things like modern e-wastegates or e-blow off valves.
  • 1 onboard wideband.
  • Configurable analogue temp inputs, with 2 different pull-up resistor values (1kΩ and 10 kΩ), allowing more types of sensors to be used.
  • Analogue temp pull-ups can be disabled now, allowing analogue temps to be used as regular analogue volt inputs.
  • K-line support.
  • CNC case, sealed enclosure.
Huge Time & Flexibility Gains For Installers
  • You can now power via the USB cable, just like the Razor PDM, making setting up the initial tune a breeze at your PC.
  • More mounting options than ever before, with through holes, and threaded mount holes on the side and underneath.
  • New WEIPU CAN connector supplies power for CAN devices, massively simplifying CAN wiring and accessory installation.
  • Highly customisable IO, with multi-use pins to maximise utilisation.
  • Similar pinouts to G4X, allowing upgrades with minimal repinning.
Inputs/Outputs
  • Control up to 6 cylinders with port or direct injection and direct spark, or 4 cylinders with direct/port staged injection.
  • Highly customisable IO, using 2 types of multi-purpose pins: ADIO pins,  and Aux./digital-input pins. These pins can act as inputs or outputs.
  • ADIO are a unique pin type. ADIO can act as an Aux output (switched or PWM), as an analogue input, or as a digital input, but cannot read PWM/frequency.
  • Neo 4 has Aux/DI pins which are used as either an Aux pin, or a digital Input pin. They can read PWM/frequency.
  • Any unused injector/ignition pins can be used as an auxiliary pin
  • All ignition and auxiliary pins are back feed protected.
  • 3 analogue inputs
  • 10 digital inputs
  • 4 temperature inputs
  • 2 knock inputs
  • 2 trigger inputs
  • 1 x wideband lambda controller
  • Dual H-Bridge e-throttle control
  • Dedicated ignition switch pin
  • 5v sensor supply
  • CAN 1 via Weipuconnector. CAN connector now supplies power and ground.
Communications
  • USB-C (cable included)
  • Power over USB
  • Connect directly to the ECU via built-in WiFi access point, or add it to an existing network (antenna included).
  • New WEIPU connector supplies power for CAN devices
  • Built in ethernet which can function like USB. Also adds the ability to connect to the ECU over a network.
  • Functional when GPS antenna is connected (antenna included)
Data Logging
  • 1GB logging capacity
  • Logging over WiFi
  • 100kHz max. total logging rate
  • 250 logging channels
  • Length: 107mm
  • Width: 158mm
  • Max Side Height: 45mm
  • Weight: 730g
Mounting
  • 4x M5 threaded mount holes on the sides for bracket mounting
  • 4x M5 threaded mount holes on the underside for clean mounting
  • 4 x 5.5mm unthreaded through holes for mounting through (designed for use with M5 bolts)
SKU: 154-5000
G5 VooDoo Neo 4 User Guide
Videos
Introducing The G5 Voodoo Neo
Charger la vidéo: Introducing the next generation of Engine Management, LinkECU's G5 Voodoo Neo. In this video, we take a closer look at the Neo’s standout features, key technical specs, and what sets it apart.
