Aim Faisceau d'intégration véhicule IVA pour la série MX Strada
IVA Vehicle Integration Harness
The Aim IVA vehicle integration harness is a pre-wired 23-pin loom crafted to simplify the electrics when installing Aim IVA-compliant dash displays. Designed for clean and efficient integration, this harness plugs into your dash and brings all essential vehicle signals into the system.
Why Choose the Aim IVA Integration Harness
The IVA harness with wheel speed sensor streamlines wiring for your kit car or road-legal project, allowing you to monitor a wide range of vehicle data without complicated setup. It is specifically tailored for the MX Strada series, offering a plug & play solution.
What Does the IVA System Do?
Allowing the perfect solution for kit car builders, the IVA system will allow you to monitor:
- All ECU information and Odometer
- Oil Temperature
- Engine Temperature
- Fuel Levels
- Side Lights
- Hazards
- Front / Rear Fog
- Parking Brake
- Main Beam
- Dipped Beam
- LH / RH Indicator
A fuel level sender can work with the Aim Channel Expansion unit with a suitable patch lead. The IVA loom has a pull-up resistor incorporated, which is unnecessary with the fuel level sender and can cause inconsistent readings. It comes with a wheel speed sensor built in, so you don’t need to add one separately.
Harness Options
23-Pin IVA Loom & Wheel Speed Sensor Kit
