Honda CBR 600RR, 1000RR AiM Solo 2 & Solo 2 DL Motorcycle Bracket
SKU: HON-B
- Prix habituel
- £60.00
- Prix habituel
- Prix de vente
- £60.00
- Prix unitaire
- par
The AiM Honda motorcycle bracket has been specifically designed to provide a simple and secure mounting solution for the AiM Solo 2 and Solo 2 DL GPS Lap Timers.
Honda bracket | All necessary mounting hardware |
Suitable for Solo 2 & Solo 2 DL | |
Honda Solo 2 & Solo 2 DL Bracket
The Honda CBR 600RR, CBR 1000RR bracket has been designed to provide a simple and secure way for mounting your Solo 2 or Solo 2 DL GPS Lap Timer on to your bike.
Please Note: The bracket is only compatible with the CBR 600RR original triple clamp.
Also available is our Honda plug & play cable for the following bike models: (Sold Separately)
CBR 600RR - 2003-2019 | CBR 600RR HRC with D11 marked ECU - 2013-2015 |
CBR 1000RR - 2004-2016 | CBR 1000RR HRC - 2014-2016 |
Example data protocols
- Specifically designed Honda bracket for the Solo 2 and Solo 2 DL
- 1 Bracket
- 1 washer
- 1 Allen screw with rounded head M6 x 60
- 1 rubber dowel
The AiM Honda motorcycle bracket has been specifically designed to provide a simple and secure mounting solution for the AiM Solo 2 and Solo 2 DL GPS Lap Timers.Key Features :
The Honda CBR 600RR, CBR 1000RR bracket has been designed to provide a simple and secure way for mounting your Solo 2 or Solo 2 DL GPS Lap Timer on to your bike. Our brackets are supplied with all the necessary hardware required for fitting to your bike. Please Note: The bracket is only compatible with the CBR 600RR original triple clamp. Also, If you are unsure this bracket will fit your bike, don't hesitate to contact one of our team. Either by email, phone or online chat.Plug & Play
Example data protocols sampled include RPM, Active gear, Vehicle speed, Front wheel speed, Rear wheel speed warning led, Engine coolant temperature, Brake pressure, Throttle position, Speed, ABS intervention, ALC intervention, Low fuel level, Traction control, Oil pressure, Map menu and many more. Refer to the technical sheet in the Downloads Tab for an extensive protocol list. Please Note: For these models/years Aim recommends not to remove the stock dash. Doing so will disable some of the bike functions or safety controls.Expand Your System
These are some of the items that can be added to your bike for incrementing performance and data. ![]() |
- 1 Bracket
- 1 washer
- 1 rubber dowel
