Honda CBR 600RR, 1000RR Aim Solo 2 & Support de moto Solo 2 DL
Choose Accessories
Mount Your System
The Aim Honda Motorcycle Bracket has been specifically designed to provide a simple and secure mounting solution for the Solo 2 and Solo 2 DL GPS Lap Timers. The bracket is supplied with all the necessary hardware required for fitting the product to your motorcycle.
Why Choose the Aim Solo 2/2 DL Motorcycle Bracket
The Aim Solo 2/2 DL Motorcycle Bracket has been specifically designed for securely mounting the lap timer onto Honda CBR 600RR motorcycles. As all components are included to set it up, it provides a quick and stress-free installation.
Please Note: The bracket is only compatible with the CBR 600RR original triple clamp.
Plug & Play Cable
A separately sold plug & play cable is also available for the following Honda motorcycle models and years:
- CBR 600RR - 2003-2019
- CBR 600RR HRC with D11 marked ECU - 2013-2015
- CBR 1000RR - 2004-2016
- CBR 1000RR HRC - 2014-2016
If you are unsure whether this bracket will fit your motorcycle, don't hesitate to contact our team.
Support Honda Solo 2/2 DL
x1 vis Allen à tête ronde M6x60mm
x2 Vis Allen à Tête Plate M4x10mm
x1 Rondelle Dentée
x1 cheville en caoutchouc
