Link G4X AtomX WireIn ECU
The Link G4X AtomX is an entry-level wirein ECU (engine control unit) for automotive applications. The AtomX ECU has expanded data logging and uses the same microcontroller as the entire G4X range. The processing unit is more responsive and has higher bandwidth than its G4+ Atom II predecessor.
G4X features 8x faster communication speed, allowing you to download logs 8x faster and push all the logging quickly up to a new and improved PCLink — available for download in the downloads tab.
Why Choose the Link G4X AtomX ECU
The Link G4X AtomX ECU can control up to 2 rotors or 4 cylinders with sequential injection and direct spark, or up to 8 cylinders using batch fire. Now featuring Knock Control, this makes the Link G4X AtomX ECU ideal for naturally aspirated engines that just need a re-tune and don't need all the extra sensors and features that come with higher-level Link ECUs.
Please Note: Requires "A" loom.
Suitable AtomX Applications
The compact Link G4X AtomX ECU is ideal for:
  • 1-12 Cylinder Distributed
  • 2-8 Cylinder Wasted Spark
  • 1-4 Cylinder Direct Spark
  • Odd Fire Engines
  • 2-Stroke Engines
  • Configurable Firing Order
  • Configurable TDC Points (for odd fire)
Data Logging
G4X features 512 megabytes of logging at 32-bit using up to 250 channels, each limited to up to 1kHz per channel (by the Operating System), with a maximum of 100 kSamples/sec.
Engine Configurations
  • Odd Fire Engines
  • 2-Stroke Engines
Communications
  • 1x CAN bus
  • 1x USB Mini Tuning Connection
  • 1 x 34-Pin Waterproof Connector
  • Upgraded Communications Chip
Fueling Adjustments
  • Up to 440 Zone Fuel Table with configurable load and RPM centres. Configurable X and Y Axis Parameters
  • Multiple Fuel Tables
  • Up to 6D Fuel Mapping (3D Fuel Table + #x3D Overlay trim tables
  • Injection Rate Control for Group Injection Modes
  • Master Enrichment for Traditional Fuel Tuning
  • Pre-Crank Prime
  • First Crank Prime
  • Crank Enrichment
  • Post Start Enrichment
  • Warm Up Enrichment
  • Acceleration Enrichment
  • IAT Fuel Correction
  • Injector Deadtime Compensation
  • Injector Short Pulse Width Compensation
  • Injector Timing Control with Beginning / End Injection Definable
  • AFR Table Correction
  • Closed Loop Lambda
  • Individual Cylinder Fuel Trims
  • Overrun Fuel Cut
  • Idle Load Trims
  • Fuel Temperature Correction
Ignition Adjustments
  • Up to 440 Zone Ignition Table with configurable load and RPM centers. Configurable X and Y Axis Parameters
  • Maximum Advance
  • Spark Duration
  • Dwell Time Table. Configurable X and Y Axis Parameters
  • Multiple Ignition Tables
  • Up to 6D Ignition Mapping (3D Ignition Table + 3x3D Overlay Trim Tables)
  • Individual Cylinder Ignition Trim
  • IAT Trim
  • Voltage Correction
  • ECT Trim
  • OEM Compatibility
  • CDI Compatibility
Limits
  • Engine Temperature Dependent Progressive Limiting
  • Vehicle Speed Limit
  • System Voltage Limit
  • User Configurable RPM Limits based on external input
Triggering
  • Digital Trigger Decoding
  • Reluctor, Optical Proximity or Hall Sensors
  • Programmable filtering and arming thresholds
  • Configurable trigger patterns or preset triggering options.
  • Supports nearly all OEM trigger patterns and custom trigger arrangements.
Motorsport Features
  • Gear Shift Control (by digital inputs only)
  • Use the G4X Storm for more motorsport features
Auxiliary Output Options
  • Each Output independently configurable
  • Unused ignition and Fuel outputs available as auxiliary outputs
  • General Purpose Outputs
  • General Purpose PWM Outputs
  • Fuel Pump Control
  • Fuel Pump Speed Control
  • Engine Fan Control
  • Air-Con Clutch Control
  • Air-Con Fan Control
  • Intercooler Spray Control
  • Tacho Control
  • Speedo Control
  • Check Engine Light
  • Purge Solenoid
  • Oxygen Sensor Heater
  • Switched Cam Solenoid Control
  • ECU Hold Power Control
  • Shift Light Control
  • Starter Control
Inputs/Outputs
  • 4 Saturated Injector Drives (suits high impedance injectors)
  • 4 Ignition Channels
  • 4 Auxiliary Outputs
  • 2 Digital Inputs
  • +5V Out
  • 2 Temperature Inputs
  • 3 0-5V Analogue Inputs
  • 2 Trigger Inputs (Reluctor, Optical or Hall Sensors)
  • Onboard Baro Correction (Real Time)
Analogue Inputs
  • Each channel independently configurable with preset or custom calibrations
  • Wide-band O2 (from external controller e.g. Innovate LC1)
  • Boost Adjust Signal
  • Configurable Fault Detection Settings
  • Throttle Position
  • Pressure (External MAP, BAP, general purpose, fuel, oil)
  • Onboard Barometric Pressure Sensor
  • Air Flow Meter
  • Temperature (coolant, IAT, general purpose)
  • Gear Detection through Analogue input, CAN or RPM/Speed Calculation
Digital Inputs
  • Each channel independently configurable with pull-up resistors and active state control
  • All digital inputs capable of reading frequencies of up to 10kHz
  • Duty Cycle measuring on all digital inputs
  • Turbo speed
  • Ethanol Sensor Control
  • Wheel Speed Detection on all digital inputs with additional general-purpose speed inputs
  • Anti-Theft control through digital inputs, over CAN or both
Processing
  • 150 MHz Specialised Engine Management Microprocessor
  • Ignition control to 0.1 degree, fuel to 0.01 ms
  • 32 Bit Floating Point Calculation
  • 12 Bit ADC Resolution
  • 20000+ RPM
  • 4GB Non-Volatile Flash
Programmable Math Processing
  • 8 individually controllable math channels with up to 4 parameters in each
  • Math channels can be used as table axes and as digital or analogue inputs
Boost Control
  • Engine Temp Correction
  • IAT Correction
  • Multiple Boost Tables
  • External Adjustment
  • Open Loop Boost Control
Idle Control
  • Solenoid Control Only
  • Reliable and accurate user-configurable Closed Loop Control
  • Air Con, Engine Fan, Power Steer, Drive Idle Ups
  • Idle Ignition Control
Environment
  • Internal Temperature Range: -10 to 85°C
  • Ambient Temperature Range: -30 to 90°C
  • Voltage: 8 - 22V
  • Operating Current: 200mA
  • Electrical protection on all inputs and outputs
PCLink
  • Adjust all parameters in real time
  • Mouse or keyboard operation
  • Tuning
  • QuickTune - automated fuel self-tuning
  • Logging Analysis
  • Diagnostic Information
  • Built-In Help
  • Definable Screen Layouts
  • Over 300 possible runtime parameters
Misc
  • Comes loaded with all of Link ECU's standard features.
  • 512MB of logging memory within data storage unit
  • 20 general-purpose tables
  • Runs on PC Link software for G4X
SKU: G4XA
AtomX Quick Start Guide
Téléchargements de liens PC
Videos
G4X AtomX Overview
Charger la vidéo: Take a look at the features available in the Link G4X AtomX ECU. It may be the smallest ECU in the range, but it can certainly pack a punch
