Link 6.5 Bar MAP Sensor
The Link 6.5 bar MAP sensor measures absolute pressures up to 6.5 bar, making it ideal for turbocharged or supercharged applications running up to 5.5 bar (87 PSI) of boost.
Why Choose the Link 6.5 Bar MAP Sensor
The Link 6.5 bar MAP sensor can be mounted via a weld-on bung, tapped hole, or remotely using a barb, and comes supplied with a plug and pins for straightforward wiring. When using Link G4, G4+, or G4X ECUs, simply select ‘Link 6.5 Bar’ as the MAP sensor type in PC Link for proper calibration.
  • Includes 3-pin connector kit
  • Mount via a weld-on bung, tapped hole or remote with a barb
SKU: MAP65
Téléchargements de liens PC
