Passer au contenu
Connexion
Rechercher
Rechercher Connexion Panier 0
Panier
Votre panier est vide.
  • Continuer les achats
    Sous-total
    Voir le panier
    Rechercher
    Link G4+ Kurofune WireIn ECU - AimShop.com
    G4K
    En stock, prêt à être expédié
    £1,225.00
    • Partager sur Facebook
    • Partager sur WhatsApp
    • Partager par Email
    • Email Partager par Email
    £1,225.00
    The Kurofune is Link’s first G4+ ECU built to run off adapter looms.
    The Kurofune is a direct replacement for a common aftermarket Japanese ECU, but with significantly more functionality and user configurability than the ECU, it replaces. Sharing the same connector footprint and pinout to this ECU means there is already a host of aftermarket adapter looms that will allow the Kurofune to plug straight in.
    Special hardware features included in the Kurofune, such as differential trigger inputs and analogue outputs which can be used to emulate a MAF or oxygen sensor, make it Link's most suitable ECU for “piggyback” type installs.
    Inputs
    10 x Digital Inputs
    3 x Temperature Inputs
    9 x Analog Inputs
    2 x Differential Trigger Inputs
    2 x Knock Inputs
    Outputs
    8 x Injection Drives
    8 x Ignition Drivers
    10 x Auxiliary Outputs
    4 x Analog Outputs
    +5V Sensor Power Supply
    Communications
    1x CAN bus
    1x USB tuning connection
    Physical
    Dimensions: 140mm(L) x 150mm(W) x 33mm(H) (without looms)
    Mass: 300 grams
    Advanced features not found on the Storm:
    30 general-purpose tables (up from 20)
    All Motorsport features including full gear shift control, anti-lag, traction and launch control.
    Link G4+ Kurofune ECU
    • G4+ Kurofune ECU
    • USB Tuning Cable
