Link 140 Bar Pressure Sensor
The Link high-pressure sensor for liquid is used for things like fuel, clutch, brake etc.
Why Choose the Link M10 140 Bar Pressure Sensor
The Link M10 140 bar pressure sensor provides accurate measurement of high-pressure systems up to 140 bar (2030 PSI). It features an M10x1 thread with a 45-degree cone seat for a secure, leak-free connection. Supplied with a mating connector kit, it ensures straightforward installation and dependable performance in demanding environments.
  • 140 bar/2030 PSI
  • Note: Up to 2030 PSI above atmospheric pressure cannot be used to read vacuum
  • 45-degree cone seat
  • M10x1 thread
  • Includes mating connector kit
SKU: HPS
  • Capteur de pression M10
  • Link M10 140 bar pressure sensor by Link, compact black sensor with threaded fitting
    Fiche du connecteur correspondant
  • Link M10 140 Bar pressure sensor by Link, compact threaded sensor shown on a white background
    Broches du connecteur correspondant
Téléchargements de liens PC
