Passer au contenu
Connexion
Rechercher
Rechercher Connexion Panier 0
Panier
Votre panier est vide.
  • Continuer les achats
    Sous-total
    Voir le panier
    Rechercher
    Link Nissan 300Link - #N300X PlugIn ECU - AimShop.com
    N300X
    En stock, prêt à être expédié
    £1,355.00
    • Partager sur Facebook
    • Partager sur WhatsApp
    • Partager par Email
    • Email Partager par Email
    £1,355.00
    The N300X ECU is Designed to suit the VG30DET engine.
    Includes an onboard 4 bar or 7 bar MAP sensor.
    It is highly recommended to fit an IAT sensor with this model.
    Suitable Applications:
    Z32 300ZX VG30DE
    Z32 300ZX VG30DETT
    PlugIn Key Features:
    Sequential fuel delivery
    OEM idle hardware supported
    CAN port
    USB tuning cable included
    Staged injection
    Knock with "windowing"
    I/O Expansion Options:
    Expansion connector 1
    DI 5 Digital Input
    DI 6 Digital Input
    Volt 8 Analog Volt Input
    Volt 7 Analog Volt Input
    Temp 3 Analog Temp Input
    Temp 4 Analog Temp Input
    Expansion connector 2
    Gnd Sensor Ground Only
    DI 7 Digital Input
    DI 8 Digital Input
    An Volt 9 Analog 0-5V input
    An Volt 10 Analog 0-5V input
    • G4X PlugIn ECU
    • Stickers
